Johnboy
Johnboy
Converting my 86 e-250 to a five speed manual. I'm wondering what to do about reverse lights? There is a round white plastic piece that a bunch of wires runs into. This piece bolted behind where the linkage hooked into the trans and rotated when shifting gears to tell the van what gear it was in I think.
The speedo cable is mechanical and I don't believe the transmission or transfer case has a spot for that. My transfercase is a borgwarner, but not the 1356. Not exactly sure what it is called, but is huge and aluminum.
My zf-5 and t-case each have one spot for wiring and it looks like the same two prong plug in both.( I'll take pics today and post them)
Not exactly sure what to do. When I turn the white plastic piece to the drive position it will start. Today I will try putting it in the reverse position to see if the lights come on.
Any suggestions are much appreciated.
Almost done!
Almost done!
