big van
Nobody Special
My van is at the shop getting the tranny done and they can't get it to shift right. Turns out the PO of my van had a 91 motor that use to have a E4OD behind it put in the van. So they bolted it to a C-6 and put it in. The E4od was elec. & the C-6 is vac. They ran constant vac. to the C-6 and this burnt it up. So I'll be putting a vacuum regulator on tomorrow when the Ford garage gets it in. It bolts to the IP. But other than that I'll have to figure it out as I go. Any body have advice? Anything special I should know about? Does this have anything to do with the throttle kick down, cause mine never worked. Thanks for the help. Matt
Here's a diagram the parts guy at ford gave me. The circled part is the regulator.
