dakotajeep
Patrolling
I was crude, I just run vac straight from the pump to the modulator on the tranny. Never a problem, and I've hauled some big loads
I might try this just to see...
Thad
Thad
It's bad for the transmission, makes it upshift to early.
My van has that problem right now, drives good if you manually shift it, but if you put it in Drive, minimal-half throttle, it will shift 1-2-3 all at once, then bogs down, and downshift into 2nd, and hold it long enough to upshift to 3rd.
Does it every single time starting off from a stop.
If you give it full throttle off the line, it will shift through the gears like it should though.
Non of the vacuum lines looks hacked or anything, but it does only have 92k miles on it, and the oil looks original.
Right now i'm blaming a sticky valve body do to the old oil, I'm gonna drop the pan, and also do a running flush, hoping that cures it....
