Bypassing nuetral safety switch
dyoung14
Is getting worn out
spencer,tn
I need to bypass it on my 89 c-6 so it will crank off of the switch again, how do i do this, i been told before but when i tryed to do it i coulndt figure it out and now i have forgot
jonathan
sullivan In
just cut the plug off and conect the wires until you find the combo that lets it crank over
yARIC008
Drives really slow
Orlando, FL
Couldn't you just run a new wire to the starter relay?
The two wires are red/blue. At the auto tranny, there are usually 4 wires. Two are the back-up lights, and the other two are the red/blue. Just twist these together and it will bypass the switch. If you look at the starter solenoid on the fender, the wire feeding it is a red/blue.
GaryB
