I was looking at my wiring harness when changing the fuel filter yesterday and noticed it looked like it was all melted and burned up. It is still connected but I cannot get it apart as both sides have melted and deformed together and looks like I have had some arcing on the edges of the exposed connectors. So I temporarily wrapped it up with tape to prevent any arcing with the body. All my glow plugs test good but the truck starts like crap in the morning when it is <40 without the block heater plugged in for 2 hours or so. I am thinking the burned up connector might be causing a voltage drop so the plugs do not fully heat. The solinoid cycles them for about 20-25 seconds when cold but it sounds like most people only get 10-15 or so.
Where can I buy a replacement connector? I have looked but cannot find it without the entire engine harness and cannot find the body site at all. The engine harness is less than a year old and don't really want to buy another one. Is there any reason I cannot cut out the connector and run sealed blade connectors for each wire individually? I know if I did this I would have to swap out engine harnesses if I ever changed engines but would there be any other problems with it?
