Cruiseomatic
Defining Insanity
Getting new cab home today and currently it's sitting on two 4X4s under the mounts.... With rockers touching the ground. It may be drug onto a rollback and most likely, the 4X's are going to try and stay put. It was lifted off the chassis but the tractor used may not be available. I'm going to try and have the driver get the bed under the 4's and back under it using the weight of the cab to push the 4's into the ground and the ground to keep them still and it slide up onto the bed. My fear is the rockers will be damaged and/or the rear corners will get damaged.
Thoughts?
Thoughts?
