Adjustment
ADJUSTMENT
ADJUSTMENT
is the key.....Seriously you have to make sure that the rears are spot on! One day I'll find the TSB again and it also indicated a larger bore MC to help with this issue. Moves more fluid pushing out further on wheel cylinders.
IIRC you can use the dually WC too but I just don't recall for certain.
Hydroboost is the HOT ticket item. and I'm sure if you check the yards up there you will find some floating around. Get it all...pedal, booster, master cyl, ps reservoir, and lines all three of em. Then once you got it all, go and do the swap you won't look back!
and as for me I'm quite picky when I have stuff that works, I'll go so far as to undo axles so I can get a super good feel for the drag when adjusting the rears too. Almost impossible to get that JUUUUUUSSSST Perfect feel with the axles in...but this is just me the OCD guy
Right now I cannot even get a brake drum off to remove my park brake cables DOH let alone do much else. They are RUST welded to hubs. NO amount of SMACK from BFH has been able to get em to budge. Just waiting to swap rear diffs! Means when I swap my rear diff I'll blow up my drums to get at the park brake cables.
Anyway
Did I mentions adjustment? Cause if not Adjust yer rear brakes!
Al
