bosch injector question
redneckaggie
rebel w/o a cause
angleton/stephenville tx
bought a set of the bosch upgraded injectors came with a bunch of u clips(for return lines), a copper washer on the shaft of the pintle, some o rings, and some extra copper washers what are all of the copper washers and o rings for and where do they go
ellis
kelso tn
the o rings are for the dust caps that hold the injectores in the brass washers are for the end of the injectores you will see when you start taking them out
ellis
kelso tn
it will miss for a little while and then will clear up it takes a little time to get all the air out i know i did the same thing
jorge140
