boost related ticking?
laserjock
Almost there...
It’s odd. Could be an exhaust leak but it’s weird that it really only makes the noise when the engine is under load. Seems like when it downshifts it quiets way down. Could it be a fuel knock? You don’t hear anything out the intake or exhaust do you?
Hell I thought mine was going to blow up for sure for the last year. At 10k miles, it sounds different than it did. It’s quieter.
no mufflers
rhode island
pulled other valve cover. cant feel any play in the valves but the cover had way more sludge then the other.
laserjock
Almost there...
That kinda looks like tell tale signs of valve guide wear to my highly uneducated eyeballs.
Macrobb
North Idaho
When really, really worn, you can hear the chuffing up through the guide. But we are talking 'destroyed guide' level of wear. Like 1/16" of clearance level.
If the guides were that bad, you should see sooty looking stuff from the hot combustion gasses burning oil as it gets blown by the valve. The way I'm seeing it, that doesn't look like soot.
laserjock
Almost there...
To me worn guides would make more noise under boost for what that’s worth.
Thewespaul
Bulverde, Texas
That’s a pretty typical for an exhaust valve with issues, could be the guide was originally too tight and wore out prematurely, the lack of lubrication could make for a cracked exhaust valve that you’re hearing.
ARP instructions calls for 125 ft lbs, so 100ft lbs isnt going to move anything. I would do a warm retorque set to 135 ft lbs, I’ve done 150ft lbs without issue and minimal stretch.
JU57US
