Boost leak?
Dieselpowerking
Lewiston, idaho
I have a boost leak in the passenger side thinking turbo and I have a leak on the driver side everything is tight though? Any ideas?
Dieselpowerking
Lewiston, idaho
Make yourself a boost leak tester. You'll be able to pinpoint it within seconds.
Will do found the boost leak on the drivers side lose intercooler boot but the turbo whistle is loud I can hear it in the cab when i start to get into the throttle and I'm at 15 psi but I havent found any other leaks.
Crawler
Dallas, TX
Pressurize the system to 30-40psi and spray all the connections with soapy water.
Watch for the bubbles.
Cv axle
