gatorman21218
Yes biobor is good stuff. used it on the boats for years and never had a problem. I would "shock" the system (read the instructions for the ratio) and buy a case of filters and put them in the cab. As the biocide kills the algae its going to clog up the filter, so even if you pump the tank all the leftover algae will still breed and make more goo. Shock the tank a couple of fill ups then if you are not changing filters like you change shirts then run the "maintenance" level.
As far as the old fuel- use it in tiki torches, as paint thinner to clean brushes(if you can even buy alkyd paint out there), start charcoal bbq with it, start a fireplace, or mix it with WMO and take it to the dump (they wouldnt know the difference).
