Hi All
Fist time poster here. We purchased a 1995 Scania K113TRB coach bus about a month ago, and began fitting it out as a motorhome. Its a BIG rig, with a 22.5T GVM, 10T towing, three axles, and 14.5M of living space. With the fuel prices of late, I decided that its 600L main tank needs to become a black diesel tank (WMO) and the 180L overflow will be kept as a 'warm up' tank for 'extortion level' diesel. Just a few problems with this idea...
1 - We are permanent travelers. By permanent travelers I mean, we refused a compulsory government medical procedure and were forced into homeless vagrancy as punishment. So a 'settling tank' is an impossibility.
2 - I cannot find anything about my engine running on WMO. Its a Scania DSC11 as the 380Hp variant, which is an 11L straight 6 turbo. Shes has a mechanical type distribution injection pump to direct injection system (from what I can see?), but not entirely sure. They are most commonly used as marine grade engines, so should be very forgiving on what you feed them. One thing I am finding with this recent move is that information about truck engines and parts is a lot harder to come by than standard cars.
3 - I'm a newbie! But I am autistic when it comes to learning a new skill. Although I've never touched an engine with black diesel before, I know how it all works in theory. But I'm on here to share my experience with anyone who wishes to follow my journey in feeding black gold to a DSC11. But most of all... to learn off all of you!
The system:
Im going to have two 110L 'dirty' tanks, where I suck all my WMO from local mechanics as we pass through town. I hope that by sucking the top of their tanks, it helps with the lack of ability to settle my dirty oil. I'll have a 220V heated "raw power" 6000 RMP centrifuge from WVO Designs, which I will set to run on a circulation loop between the two tanks while driving with a 2L/min oil feed pump. This will give the oil anywhere from 3 to 6 hours a trip to cycle through the centrifuge. Once its spent a good time in circulation, it will gravity feed through the centrifuge one last time into a separate 300L 'clean' tank. After which, I will add my 15% ULP, and let the gear pump cycle that tank and blend the ULP with the clean WMO. Once I'm happy with the blend, I will then set the same gear pump to fill the main 600L vehicle tank... and viola! I hope... haha!
Anyway, hi again, thanks for your time to read my post, and feel free to feed me as much of your knowledge relevant to my situation as possible!
Bernie
The system:
Bernie
