Cheaper Jeeper
Came out of work yesterday and saw a big puddle of coolant under the front end of my truck. After spending a couple of minutes looking around under the hood and front end I could see that it was dripping from the underside of the harmonic balancer. A little more looking and it seems like it might be coming from the underside of the water pump - maybe somewhere towards the driver's side.
Here's the bizzare part. When I filled it back up with water (6 quarts) and started it up, the leak seemed to stop almost instantly. I drove it 40 miles and stopped several times on the way home. No signs of leaks. After I got it home and parked, it still wasn't leaking. BUT, when I came out and checked it after it had been sitting for about 5-6 hours and cooled down, it was leaking again! A steady drip...drip...drip from the bottom of the harmonic balancer just like before.
So what is up with that? I have never seen an engine leak when sitting cold but NOT leak when running and warm before. Usually when they warm up and the coolant pressure rises, they leak worse. In my experience they always leak worse when running than when they aren't running - due to the pressure created by the water pump.
Anybody ever seen anything like this? My first thought is that maybe it is leaking on the suction side of the water pump where it bolts to the block. Where are the suction ports on the whater pump? Top? Bottom? Passenger side? Driver's side? Any other ideas/theories?
