papastruck
With some desperately needed assistance, I jumped into my first bodywork project. I did dent work, while the panel replacement was done by someone more experienced. Haven't done any filler work yet; I'll post when we do that in the next couple weeks.
Before:
Removed the rot with a small electric grinder. About half a bucket of dirt fell out when we pulled the panel off. If you don't have a bed guard like this does, it's worthwhile to stick the sprayer down that middle stake hole when you go to the wash. We didn't cut the ends of the replacement panel, just the top. Were I to do it again, I'd cut about 3" off each end as well, as the panel has a crown to it that will require some additional filler work. That amount reduces the effect of the crown without having to pick around the wheelhouses when cutting, which would have been more work than it was worth.
Sorry 'bout the bushes; parking's that tight. Again, no filler applied yet. Panels are from TABCO.
I also pulled a bunch of dents out. Here's the worst one, which I didn't have time to finish and which is buggered up enough that I'm thinking about heading to the junkyard with a sawzall and grabbing the right tail light area. But from about 4" ahead of the tail light, it popped out nicely, the remaining work being the body line on the bottom. I'd lined up the 3 gouges with about 30 studs to pull, but what got it out was actually a few well-placed studs running about 2" in front of the light.
We're going to leave it white only, which is what this truck was originally. It will hide blemishes for a first time painter, and while I always thought the 2 tone paint schemes were some of the best things about these trucks, it's not worth the time and expense in light of everything else it needs IMO. Besides, can you not come back, mask, scuff, and paint a side of color down the road?
Before:
