Best way to clean my pistons
Twostacks
howell, NJ
Whats the safest way to get carbon material off the piston heads.
The manual says to use a solvent but didn't specify which. What do you guy recomend?
Thanks
Vin
Diesel JD
Gainesville, FL
I haven't built an engine but I know biodiesel or even regular diesel are excellent solvents. I'm in part bumping this and hoping some of the more experienced guys will pick it up.
BigRigTech
Diesel junky
Nova Scotia, Canada
All I ever use is a wire wheel on a die grinder or a small wire brush....Works like a charm as long as you keep the speed down....Water takes carbon off the best from what I've seen.
SparkandFire
We're drinking beer
Aptos, CA
X2 on the diesel/scotchbrite pad.
We clean the carbon off our boilers' burners with that combo, works nice!!!
Mercury outboards makes a carbon cleaner that works great. Ask for it in a mercury repair shop....
Full Monte
Campbell, CA
I wonder if Techroline made by Chevron could be used with diesel as an additive. That stuff is amazing in a gas engine, but check for compatibility with diesel fuel.
RangerDanger
