I'd have to second a lot of the suggestions here on whatever turbo suits your needs, and plenty of gauges. Then I'd certainly have to say get a fresh fuel system and... MOOSE IT!
Sorry couldn't help it. If you get serious about power though, Mel (Agnem) is able to fix you up with what is arguably the best IP available to us, while Russ will be able to provide you with a re-ground cam that has had some pretty good reviews for bumping up torque. Either of these members can set you up with a set of quality pop-matched injectors, and unquestionable, unmatched service.
Hypermax makes an intercooler fit for our engines, but it is rather spendy. I, like several others, put together my own kit with less than $400 in parts, and Russ can also provide you with an aluminum intake hat for that project if you so choose.
Good luck and welcome to OB.
