jaed_43725
Need Quad Cab 4x4
Heres the story. I was having a leak by the petcock valve on the bottom plate, not the valve itself but the one that looks like a tire valve. So I took it apart, and the filter was dirty so I figured it must have built up pressure being dirty and started forcing fuel out of it. I cleaned it with some carb cleaner and it looks good now.
Went around town and all the ones I seen at Advanced and O'Reilly had plastic threads for the bottom. Is there a all metal one? Do need to go to a IH dealer? Part numbers would be of help. Also what about the kind that have the drain as part of the filter?
