Bed R&R 1994 F250 ?
rkpatt
ATL , GA
It looks like that I am going to have to remove the bed on my 1994 F250 IDI to deal with fuel tank sending units. A walk-thru / any tips on this procedure are appreciated. - Thanks
adam g
Emporia Ks
I work in a shop that does a ton of fuel pumps we usually drain and drop the tanks seems easier.
BROWNIEBOY525
The old fleet
south jersey
if he's doing both tanks then it might be simpler to pull the bed if he has the man power or something to pick it up with then you can just leave the tanks on the truck. there are six bolts they are not the simplest to get to and if they have never been off your in for some fun:mad: mine had carridge bolts in them but it didnt work because the bolt would turn any way so i had to weld a nut onto the top of the bolts then just hit them with a impact gun. then unbolt the filler necks and unplug the rear lights and its should come off.
TLBREWER
Windy B Ranch
Moriarty, New Mexico
Three people can lift it off. While it's off, take the time to pressure wash all the years of accumulated crap off the frame and bed underside.
Tom
I had to get out the torch to do mine.
