rodymartin
The 85 F250 I am getting has a dual battery setup like the 90 I have. Is this stock and what batteries are used in it?
Plus the reduction starter spins them over faster
No, I've got it right, the motors on the gear reduction starters turn at a much higher rpm but because of the gear reduction turn the engine over with much less effort. I have changed out many delco starters to the gear reduction Mitsubishi style, gear reduction always turns them over faster
Gear reduction spins faster. IIRC, the gear on the motor maybe bigger then the gear it engages (the one that the bedix is on). Big gear turning smaller gear means it turns smaller gear FASTER. Direct drive starter turning at (example) 1000 rpms vs a gear reduction motor turning at 1000 rpms.... the actual RPM sent to the flywheel would be much faster.
I'm a firm believer of gear reduction starters. I've refit my own JD2240 w/ one. Before the g.r-starter, it had a hard time starting (and yes, I checked everything.)
