Battery cables
PROFG
SE CT
The difference is all current, load and charging, should enter the batteries BALANCED. Positive on one batt, neg on the other, NOT both batteries grounded separately. Impossible for both to have same charge/discharge action. Negative lead could go to one starter mount bolt for better cranking with cable to now vacated (of batt neg leads) ground junction in center of crossmember to pick up rest of the smaller loads. Pictures and numbers to follow after I get air leaks solved.
Selahdoor
Index Wa
This is what the actual charging circuit looks like. (Most basic drawing.)
Current from alt goes to the positive side of the solenoid, then to the positive side of one battery. Then from there to the positive side of the other battery, via a cable straight between them.
Negative goes out through the alt case. To the engine block. From there it goes straight to BOTH battery negatives.
I fail to see how a dedicated cable between the two battery negatives will change the charge properties. Let alone improve them.
If anything, for an improvement, or at least an equalization... You should be running a cable from the solenoid positive, to the secondary battery positive.
But I don't think even that would make much of a difference if any at all.
chillman88
Central NY
His point is that the passenger side battery should NOT be grounded to the block and the ground should ONLY go to the drivers side battery and then from the drivers battery to the passenger.
This way the electricity basically goes out the passenger side and back in the drivers side. This way the passenger side battery is not getting more load than the driver side (being the passenger side is the "shorter" circuit).
Selahdoor
Index Wa
So, in essence you guys are saying that the path to ground should be made longer for the driver side battery.
I still fail to see the improvement. I still think an equal path for the positive would give better benefits.
And I don't think either one is needed. I think you'll see more benefit in the older trucks like we have, just in new cables all around, and all connections cleaned up and sealed.
I believe that they're saying that the path to ground for the passenger's side battery should be made longer. The two batteries should be connected by the ground cable. The ground should run from the block, to the driver's side battery, and then to the passenger's side battery. In my mind, this seems like overcomplicating things. If you have two containers that are connected by a hose toward the tops and you fill one with water, then the other will also be filled. It may be slower, but it will still be filled to the top with water.
I would agree with this.
Pat Tavelli
Oroville,Ca.
Hello all,
I know making our own cables is preferred, but in the interest of time I need to purchase pre manufactured cables. Here's the history.. my truck has started doing the clunk, clunk, clunk roll over clunk a few more times then hold my mouth right and cross my fingers the starter will spin. First thought was new starter, but after fiddling with the cables everything is good in the hood for a while, then back to the clunk. Fiddle with the cables again and it's fine again for a while.
I'm going to replace the cables first, so I was wondering if anyone has tried standard motor products positive cable. Rock Auto has it listed for $72 ish, NAPA wants over $100 and I'm not even going down the stealership route.
Thanks all
I thought I needed a new startrr
Hello all,
Thanks all
Hello all,
Thanks all
PROFG
SE CT
The improvement in charging is overshadowed by major improvement in battery life due to high current cranking equally supplied by both batteries. Slightly longer ground cable to starter will be larger cable (sum of circular mills of both existing neg cables). If it starts on first rev with no extended cranking sessions, mod maybe not necessary. Just measure cranking current each batt negative cable to see difference.
PROFG
SE CT
Analogy is correct. The second, battery, will charge slower and discharge less current. First will probably die sooner depending of which is more damaging, slower charge or higher current share. Small differences in measured charge/discharge battery voltage equate to large current differences due to small internal resistance, damn Ohm's Law again.
PROFG
SE CT
This, might, slightly improve charging only with very little cranking effect. Highest load is cranking, that should be balanced with pos and neg cables to STARTER, with smaller cables to frame ground and solenoid/alternator. Almost the only designs like our trucks are done by manufacturers saving a few cents per vehicle. Check out how the rest of the world connects parallel batteries. For a hoot, check out 3 or more in parallel.:rolleyes:
https://www.impactbattery.com/blog/tutorials/how-to-charge-marine-and-rv-batteries-in-parallel/
Picture is worth a thousand words.
Now I see what you are saying. We have a few dump trucks setup that way.
Selahdoor
Index Wa
I wasn't thinking about cranking.
And as Jasper said, the pictures and reference are invaluable!
You are correct.
u2slow
bilge rat
Coastal BC
Agreed. I did exactly that in my 97 E350 (powerstroke) because the engine always had starting issues. #2/0 from each battery (mounted side-by-side) combining to #4/0 for the leg to the starter.
In these cases you need every volt and amp for as long as possible... meanwhile the automatic GP system happily drags your system below the IDM's 10volt starting threshold. cookoo
Selahdoor
Index Wa
Starter is 'technically' closer to the passenger side battery, right?
I believe the GPs draw from there, as well, right?
How about moving the GP system to draw more from the driver's side battery?
