Where are you guys ordering cable for your batteries? Seems not many places local carry big cable and the ones that do are pretty pricey. Where have you guys ordered online with good pricing? Thinking 2/0 for grounds and 2/0 between positives then 3/0 to starter and ring lugs on all connections. I don't want a factory style positive cable, particularly since cables are cheap I'd rather spend a little more and go overkill so I don't have to worry about it again.
I don't have stud posts on my batteries but will either get adapters or just bite the bullet and get group 31s. Had a no start the other day at 2* in the morning and had to drive the 460 truck, and that was a bit slow to turn over with a fairly new 810 CCA battery and 2 gauge cables. Anyhow, one of my ground cables has a cracked clamp and was loose so I think it was only trying to start on one battery that cold morning. Got two tries and she kind of sputtered a bit and stalled then that was it for spinning fast enough to have a chance. Figure I should just replace and upgrade all the cables since they're old and ratty.
