GREASE FIRE
i had a problem where the windshield wiper motor was staying on even with the key turned off - and because the motor does not work anymore it was basically just draining power from the batteries. A friend was using the truck for a couple weeks and i guess he did not hear the quiet sound it was making....
so it eventually ran the batteries till they were totally dead (everstarts bought this past Feb) and i put them on a charger for a long time - about a day and half at least until the green light came on with the charger, indicating the charge was complete. I also had the batteries tested at the local shop, where they were said to be good still.
But, when cranking (and this truck takes a lot of cranking to start) it turns over a lot slower than before this happened.
Any idea what happened? could the batteries have got messed up from this incident? If anyone has ideas on how the get the cranking rpm's back to where they were i would like to hear them.
The only other thing i can think of is that one of the battery cables looks pretty beat up right where it connects to the terminal - the casing is split and the wires inside look kind of corroded. But it is not that bad looking, and the guy at the shop said he has seen a lot worse in trucks that cranked over a lot faster.
Any help appreciated!
thanks,
Paul
thanks,
Paul
