abfiegen
My truck has been in storage for about a month now. Everything seemed to work just fine when I parked it. I went to start it today and it had no power. No headlights, backlit gauge cluster, glowplug relay click, etc. The only electrical issue I've ever had was a parasitic drain from the dome light being stuck on. I removed the fuse associated with the dome light and it has been that way ever since. I THINK this fuse also had the glove box light on it?? I also recently installed an electric lift pump in place of the mechanical lift pump. It's on a relay. It has sat for multiple weeks without battery drain since installing the new lift pump. I haven't had a chance to do any troubleshooting cause it's parked in a storage unit barely long enough for it so I may not be able to answer many questions yet. Thoughts??
