Hello all! I recently bought a used banks sidewinder kit for my 86 f350 but it is missing some parts. The main one being the oil feed line. My question is can i just use pipe fittings on the top of the turbo and a compression fitting to some steel fuel line down to the side of the block to get oil up to the turbo. This was the way my hypermax was set up on my other truck. The reason i ask is cuz i was searching on ebay for oil feed kits for turbos and they say you need a special oil feed block(part that bolts to top of turbo) with a built in oil restrictor to limit the amount of oil pressure up to the turbo to keep the seals in the turbo from blowing out. Is this true? I know i can do it alot cheaper by just using pipe/compression fittings and steel line. Thanks for the help in advance!
