Banks Sidewinder question
Steve Olkowski
Hi, I am interested in buying one that is in the marketplace, but he says its for a 5 speed. Do you guys know if it will work for a c-6? Also may need some pics if it does work of how cdr valve and such may mount. Thanks, Steve
Actually I need more info on this turbo. Is it waste gated or not.Usually the only reason this turbo wont work for you is the exhaust drop down pipes are trans specific. Pics sure would help us explain if this is going to work.
Steve Olkowski
It is the wastegated turbo, from what I understand, but banks list separate numbers for 3 different kits based on transmission.
Thanks for the pic location.That turbo will fit but you probably will need the crossover exhaust pipes.Banks still sells them.
Alleycat
