adam g
I am working on a customers van. The customer owns a construction company. His help against all warnings still used either on it. This thing is hard starting even hot. When started blows white smoke,and misses under a load. Sounds terrible. I put my lisle hydrocarbon/head gasket tester in the radiator. It passed. I took compression through the glow plug holes. 7 cyl in the 400 to 425psi range. One hole wouldn't quite make 350. Is that enough to cause a dead hole or do I have a bad injector that has washed down that cyl. Customer complained of having to add a quart of oil every 500 miles but for a 200,000 mile motor I thought that was bearable. Oil was right at full didn't appear to be contaiminated with fuel or antifreze. What do you thinK?
