rhkcommander
Hey guys,
Not sure if my alternator regulator is shot or not, I upgraded to a 3g a while ago.
I installed a volt meter (along with oil pressure and coolant temperature), truck has been getting harder to start lately. Voltage at all speeds is about 13V, doesn't seem to go up with RPM. The gauge is analogue and my electric pump makes the needle jump quickly... (side question, any way to fix that issue?). When hitting the glow plugs it dives down to high 10s, cranking with them on to low 10s.
If I turn on the blower, wipers, headlights each will cause voltage to drop.
The belt squealed the other day when I revved it after cold starting, so I'm assuming it was trying to generate.
All of the contacts should be clean and tight but I will triple check. I use a 150a re-settable fuse on the lead, with the smaller wire tied into the fuses post to pick up voltage.
Thanks for any advice.
