Back form the Machine Shop....... Again.....
Mat J
Way down south
Jupiter, FL
looks good but if they put them in wrong the first time doesnt that make you wondering about the rest of the motor.
(by looks good i mean clean not necessarily put together right i dont know)
Sorry but no way can I tell you if all is ok by the pictures you supplied. The rods need to have the large chamfer pointing to the crank webs and the small chamfer points towards the other rod on that bearing.The top side of the piston must have the flame trench closest to the intake manifold or to the cam side of the cylinder. The rods need to have the big weight on the small rod end facing the outside of the motor or cylinder. Hope this help.
typ4
Newberg,OR
Looks like the "narrow " sides of the big end are together which is correct. I would check torque on everything they touched.
