Back brakes
jw674
jermyn pa
1992 f250 ,im doing the back brakes.do i half to remove the hub?never done back brakes before.thanks
A 92 should have a Ford 10.25, which has seperate drums unlike the Dana's from the 80's that have the hub and drum as an intergal part. Just take off your wheels, release the parking brake, and if the God of drum wear looks favorably upon you, the drum will just pull off. Otherwise, get out your brake spoon, a screw driver, and start crankin'.
