Axle bolts
Anything special about the sterling axle bolts or are grade 8 replacements suitable? Follow-up question. Blue loctite or red?
DaveBen
Ukiah, Ca
Are you referring to the ring gear? They are grade 8 and and I have used Locktite blue. I seem to remember that there was a locking washer/bracket with the bolts, so no locktite if so.
Dave
Thanks for the link. That seems pretty overkill though. If these bolts didn't look a little rusty where they go through the axle flange I wouldn't worry about it. Google is failing me. Seems like I've seen Russ say something about these bolts but I can't remember what.
@typ4
junk
Paullina, IA
Russ recommends new bolts from ford. If I remember correctly. I also thought I read to replace them if they don't torque up Ok. If the torque then it sounded like no issue. I would use blue loctite personally. I rarely to never use red.
jhenegh
Truck Still Earns its Keep
Deerfield, WI
The E350 Dana 60 full floater hub bolts I think are regarded as better? Say outta a 1999 E350
Thats true. I have a source I thinc for new place bolts maybe I should supply these too.LOL
FWIW, Dana uses the same bolt.
Think I found them. Trying to run down specifics. PN I found seems to be FORF100114
I can't find out if that's for a kit or what though. Asked sellers, waiting on responses.
@typ4
IIRC the reason the D60 bolts are better for both axle and ring gear is they are a shouldered bolt not a full threaded bolt thus fit the bolt hole in axle even better....or ring gear...
I could be wrong....but ....
jhenegh
Deerfield, WI
Picture with disc brakes is a 10.25 hub/axle with Dana 60 brakes installed and axle bolts. The bolt heads are bigger.
Picture with drum brakes is a 10.25 hub/axle with the factory brakes and axle bolts. Smaller heads.
I don't have any pics of the bolts out, but they are different at least in this perspective.
So east coast gear sells these as an "upgrade" for Dana 60.
$2 a pop. They are approximately grade 9. Available also from McMaster-Carr a bit cheaper.
JFMac
