Hydro-idi
You can bleed the air from the system by cracking lines loose at the injectors & cranking for no more than 15 seconds and then waiting 2 minutes for the starter to cool down. Of crank for 15 seconds with the lines tight at the injectors. Then loosen them and watch and loosen for air escaping. You do not need every injector flowing fuel for the engine to start. If you have the easy to reach injectors on each side that will get the engine running. At least 3 well bled injectors will fir off the engine. Then the others will clean up as the engine runs.
You wont see lots of fuel at the loose injector line. These diesels burn very little fuel at idle speeds. The most you will see is a small drop of fuel. Now what will make you feel something is wrong is when the fuel finally is pressurized to say 1850 lbs only then will you see fuel squirting out of a loose fitting. Remember its only pressure with a very low volume of fuel. Also be careful not to allow the high pressure fuel touch your hand. It WIL get injected under the skin and cause all kinds of trouble.
Gary, I have always had problems starting my engine after doing Any IP system work to it....with cracking 1 injector at a time. When I did HG's last year, I cracked them one at a time and that got me nowhere. That's with fresh batteries, cables, GP system, block heater plugged in, aux fuel pump etc. I then cracked them all open and that did the trick. Guess every engine might be different tho.
