Ats 085 t-19 to zf5 compatibility?
Austin86250
idaho
I’ve got a host of parts trucks now which means I’ve gots me a zf5! I plan to sell it unless it will work for me
As the title states will a ats 085 work with the zf5? It has the t-19 right now
Reason I ask is I know banks is trans specific
I think banks manual kits are interchangeable, it's the c6 and E4od that use different kits each.
Ignore the mess.
Two different pedestals, early automatic on the top, and later ZF on the bottom. There may be more but these are the only two I know of.
Which one does yours look like?
Shoot.
Late night brain fart.
I'll check out for the evening.
Black dawg
sw mt
The cast piece/upper up pipe won't clear the added depth of the zf5 bell
Austin86250
idaho
Darn, was hoping for better news but that’s what I expected thanks yall!
Black dawg
sw mt
I’m hearing you can cut an ear off the zf bell housing to fit? Do you know anything about i
I went out to my parts pile, and set an 085 exhaust side on a 7.3/zf combo. It does look like it maybe could be made to work as far as fitting over the bell, with modding/cutting the bell, but the up pipe would have to be routed slightly higher and may have cab clearance issues also. The bellhousing may have to be cut enough, that welding in new would be needed.......
I personally dont think the 085 kit is really worth that amount of work. I have the same turbo on my truck, and have not put my zf5 in yet because of this. I have most of the parts to put a factory kit on my truck, and as soon as I finish collecting parts will be doing both at the same time.
Austin86250
idaho
Thoughts?
I’ll be rockin this turbo kit for the near future probably until I get my settlement money lol it’s about all the 6.9 will handle anyways
hacked89
Bucks County PA
Thoughts?
Does it fit out of the box, no.
Do most things fit with cutting and welding, yes.
Have fun - document what you do and make a How to Modify ATS085 for ZF5 thread.
Black dawg
sw mt
Thoughts?
pm me a number I can send a picture to, and I will send a picture of what it looks like mocked up. will have time to do it later today.
morerunner
