Hey gang,
Have a 1994 IDI, turbo, 159k.
Threw a belt yesterday and it bent the tensioner into the idle pulley and fan blade. First time the belt came off since I owned the truck (about a year).
I did a search on belt tensioners and the general consensus was it was fairly simple to remove. Well I can't get the idle pulley off or the belt tensioner. Seems like everything is designed to be in the way.
<rant on> Man, I hate Ford. Have had Fords all my life and it seems like they need so many special tools or you have to take the truck half apart to fix one broken thing. Maybe all makes of trucks are like this but the last decent Ford pickup I had was a 1981 F150 6 cyl with manual transmission. Now that was a real truck! Enough whining. <rant off>
OK, back to the real world. How do I get the damn idle pulley off? What size Torx is it? I thought someone here said it was a 40 but it seems like it's a 50 but it just doesn't seem to grip right.
Would taking off the fan blade help?
I tried to get the vacuum pump pulley off but the bottom bolt on the right won't come loose. Another impossible place to get your hand and a wrench. Arghh!
Any help would be appreciated.
Thanks
Thanks
