Are 6.9L engine mounting dimensions close to that of a Ford 460 gas engine?
Ataylor
Placerville, Ca
aofarrell2
Turbo Desirous
IA
The 460 is a bigger motor is all I can say... I don't believe they even use the same mounts.
Ford428CJ
FE Freak!
Klamath Falls, Oregon
You have it backwards. The 6.9 is much bigger! Outside dimensions for sure! Trust me... I converted my 79 from a 460 to a 6.9. I also had to install a body lift on the P/U. Otherwise it wont fit. JMHO
sassyrel
iowa
MUCH heavier weight wise also............
hesutton
The Anti-Anderson
Bowling Green, KY
Iowa 73
FNM
IA
I have a couple of each sitting in my shop, but don't have time to measure the mounting points right now.
You are going to have to fab on it anyway, and I don't think it will be too far off. Just depends on how much work you want to do.
I have fix or six engines in the shop and no stands... I use tires and wood blocks.
Ataylor
Placerville, Ca
Dang, I was hoping it would be close. Well, I guess I will have to make my own.
Thanks to everyone for their responses.
Archie
aofarrell2
Turbo Desirous
IA
Sorry I was thinking about another engine! I got the 6.9 confused with another 6.x diesel LOL!
