anyone identify this rearend?
Kistthesky
AZ
coming out of an '84 F250, pretty sure it's not the original as per po, has left handed lugs on the drivers side- do i need to keep those for some reason?
Dana 60 or 70 look for tag under the goo under the bolts on cover also should be a cast 60 or 70 on housing as someplace. Likely stock
D-70 HD? 4.56 gears?
sure looks alot like mine.
came out of a 80's F450 utility truck
left handed threads on one side too
Thanks Ken. Something to put on my wants list... A set of 3:73...... My 3:55 is well worn out.. Lots of slop in the ring to pinion gear.
Kistthesky
AZ
looks like it, definitely gonna take a hit on the mpg's!
mccall52
Woodstock, GA
1984 is most likely going to be a Dana axle, I think Sterling axles were phased in sometime during MY1985.
Leeland
Oregon
2nd column 4th down. Clean out your eye balls.LOL
Maybe I need to clean out mine now cause your 9" post IDIoit pulled a Houdini.
