Any sources for Motor Mounts?
Knuckledragger
Payson, AZ
Thankfully, the mounts are not in question any more, and the noise has mostly disappeared. I am still going to lube the u joints to see if that does anything.
Detonation is a deep knocking or popping sound (I have heard it a few times - not fun), this noise is more like preignition. Maybe I need to check the spark plugs.
FarmerFrank
Blairsville, Pa
On the subject of motor mounts, summit racing has them. None of the local places could get them. Cross referenced the number and it came up the same for 94-97 strokes. I ordered a set and should have then in the morning. Ill find out
Knuckledragger
Payson, AZ
Gary wins the guessing derby!
It was the rear U joint and I guess the racket was being made while the rollers popped out. The tinny sound is the driveshaft singing. The truck oddly made no complaints but the noise until the last day. When I shifted into or out of gear, it would make the tinny popping sound. Now I know that was the driveline taking up the slack left by missing rollers in the U joint.
Thanks to everyone for your input!
Thanks for the update Mike. That sound is made by the failing u joints echoing thru the hollow drive shaft. Its a sound you will never forget either. I hear it sometimes at stop lites as we all start driving off. You just know someone has no idea whats about to happen to their driveshaft when it falls down in the front. Sadly these drivers will continue till they need a complete shaft replacement.
Nanohawk
