Another Interesting IDIT Failure
austin92
Brazil. IN
Every other oil change I put a bottle of seafoam in the crankcase while I’m pulling the truck into the garage. Thoughts on that?
Clb
Another old truck
nannyfornia
To short of a soak???
+1 caint hurt nothing...
What was diesel rx service interval???? 3 oil changes???
Clb
Another old truck
nannyfornia
Here's a fwiw...
Back in the day...
I hauled an old willy outta its hibernation, flushed fluids, hot plate under engine,
No spark...
Dist. Locked up tighter thanna ducks ****...
Soaked it in a can of diesel for a week or so, hit it with compressed air, stuffed it back in, fired up.
ttman4
Last Nite's Dream..
Hopefully you didn't proceed to wash them in [leaded] gasoline with your bare hands in your kitchen...
I waited till Carol was gone & then I ran them thru her dishwasher.......LOL
(I got to hurry up & get my shop built so I got somewhere to sleep....gets old sleeping with the cats!!!)
PROFG
SE CT
What about, say 5 cranks of the engine with the key out of the ignition?
Hey, best thing about this, is that you can still put the diesel in the fuel tank afterward! :D
What about some ignition off cranking with filter still removed to flush oil cooler? No chance of entering oil gallery and could see when flush "complete"? Then drain, flush with oil, install oil filled filter and oil, and proceed as normal.
DrCharles
West Plains, MO
I think it would be a lot safer to pull the truck in, shut it off and set the parking brake, THEN put the seafoam in :rotflmao
Probably doesn't hurt anything but I'm not sure it really does much either. Every brand of additive has its fans...
At the last oil change, I put 3 gal. of old diesel in my crankcase and let it sit for 2 days before draining and refilling with 15W40. The diesel did come out dark, but not near as black or goopy as I had been expecting. Maybe my IDI was just cleaner in the pan than some...
Seven4eight
