foresterdj
Same symptom as earlier this month (well, almost the same, no WIF light issue this time)
http://www.oilburners.net/forums/showthread.php?56400-5-months-good-now-nothing
This morning, hop in, turn key, WTS light flashes on, then off, try starting, spins like crazy, no start.
Check schraeder valve, lots of fuel.
check power at fuel shut off solenoid, it has juice
spin it over more, some puffs of white smoke at exhaust
check glow plug with switch on, NO juice; and engine is cold, and it is 50+ degrees.
Figure I will plug in block heater for an hour.
When I go back, turn key and *&^%$#%%^&&*, now WTS comes on and stays on, I do not even wait for it to go out, hit switch and it is running instantly.
So we can figure it has had fuel, spins good, starts fast once warmed a bit, but the big question remains.....
Why was the WTS flashing on then off before, and why does it stay on like it should later, and how is this affecting the starting (not starting) of the truck? I am thinking some kind of electrical intermittent problem? But what is going on? Glow plug relay was new in October 2011.
