jaluhn83
There is so much more to it than that, especially when an alloy is made for the purpose of having a higher melting point than the base metal. Example: iron melts at 2300, while medium carbon steel melts at 2700.
You're backwards. Pure iron is ~2700*F. This is why wrought iron was used for so long because it was very difficult to get hot enough to truly melt pure iron. Also part of why the blast furnace works - you're dissolving carbon in the iron as it's reduced thus creating liquid high carbon (and thus lower melting point) cast iron.
Alloying is very very complicated. Most of the time you're not trying to raise the melting point, but rather trying to extend the working temperature range or increase strength in some way.
Really, the melting point is meaningless from an engineering point of view, because long before you get to that temp the metal has softened to the point of having no strength.
Most likely the bulk temp of the pistons isn't much over 300-400* since you've got constant heat flow out of the piston into the cooling oil and the cylinder walls. Anything over that and you start getting serious problems, not just due to metal softening, but also thermal expansion.
Steel pistons may actually be worse due to the lower thermal conductivity - they may loose strength at a higher temp, but will run hotter since they woln't shed head as easily.
Ceramic coating the crowns is certainly a good idea period just to reduce the heat load going in.
The myth of the 1200* EGT being based on aluminum's melting point is just that - a myth. Really it's based on the heat flux through the head, piston, chamber, cylinder, etc and damage due to piston overheating, thermal stress, scoring, etc.
Also, are not hyper-eutectic. Hyper-eutectic don't really get you that much. If you read the article that was linked, you'll see that it's mainly to reduce thermal expansion allowing for a closer cylinder fit to minimize cold emissions. The additional silicon also makes the alloy more fragile which is obviously not a good thing. Said article stated that most diesel pistons are a 2613 alloy with low silicon levels. 99% are cast as well due to the need for a steel top ring groove insert.
