Well to start i will go with some history on what has occured thus far. About a month ago my SD started to act up on the heat end she was getting up to about 100-110C on the stock temp gauge and with that i discovered that the waterpump was dead and also that the thermostat was stuck closed. So New water pump , new thermostat. No problems untill earlier this week temps started to rise up again to about the same range upon whereas revving the engine at the light would drop it back down. OK. This thursday i got to my site at work and was about 45 min early and the temps had gotten up again right before pulling into the lot. Ok pop the hood looking see coolent around the top of the rad and it appears that the fluid was dropping again from the water pump again. Upon further investigation i saw that the upper hose was leaking and this was dripping the coolent al over the place. I am thinking problem solved. So i wait untill the engine cools off crack the top hose off to refill and take a closer look... The piece that the hose clamps around was snapped into two large pieces. Great i am at work and i have to get this car home. So i called the warden and he said i should loosen the cap so no pressure builds up and makes the top hose blow off. On my way home which was in two legs had another stop to make i made the first leg no problem she dumped a little coolent at the stop so i topped her off and headed for home get back on the 280 from bird ave, temps are looking good hit the 17-280 interchange and get over the top of that and boom temps shoot up... Immidiately pulled her over to the shoulder and mind you this is at about 2 in the morning. So i get over and shut her down call AAA. AAA gets there in about twenty minutes Brand new peterbuilt tow truck so it was a nice ride. Oh and for humor while the driver was taken me and my car to my house he got a service call for a 2007 prius that wouldn't start... In Closeing does anybody know where the cheapest new rad would come from? I am going to look at preformance products and do a google search. thanks in advance for the time and letting me rant
