Where's Chris? Like stated above, he did this back in 2008 and had some issues. I'll shoot him a PM and see if he'll put his two cents worth in.
Heath
thanks for the heads up on this
. as stated previously i had air on all four corners. i ran four links with pan-hard bars front and rear, on board air, D.O.T. tubing, valves, heaters, dryers, condensate blow off,air pressure gauges, switches in the cab, etc. look
here, here, and here. it worked great till i lost an air bag. they stopped manufacturing the style i used. i tried their replacement but had no luck running them in the rear, so i removed them and installed springs with a rear shackle flip to get the height i needed. i have plans to remove the front as well and run a coil-over/ radius arm set-up. any questions ask away
