Adding atf to diesel fuel
div7racer
Southern Calif
When I was filling up my truck tonight,a guy with a 1995 3500 box truck told me to add a quart of atf to each tank of fuel.He said his truck has 350,000 miles on the origional motor,and runs like the day he bought it (and has never even had the valve cover taken off).Is this a common practice,either with atf or some other additive?Just wondering what the experts here think.
rubberfish
Langley B.C.
It won't hurt anything. Using ATF is kind of old school.
Along with 2cycle oil and the likes. Proper store bought
stuff is good as well. Try to use something, take your pick,
at least every other fill-up. It's good for the inj pump.
Especially since the brewers have been going with a
"lower sulphur" blend of fuel. That used work as a lubricant
for the pumps. Now it's recommended you add it yourself,
not sulphur, but the other stuff. Everybody has their fav
for some reason or another, either cost, availability, etc.
Pick one, any one, it does a pump good. Personally, I'm
not loyal to one, I use what ever I get my hands on.
Whit
lost in Why-homing
I agree that something needs to be used as an additive but ATF wouldnt be mt choice, Never know exactly whats in there fer sure, My choice is any fuel aditive as thats what it is made for, Atf wont help as a centane booster or a anti-gel, there are many quality additives out there that will have the whole package,I know in the olden days alot of folks would use their used motor oil in their fuel too cookoo JMHO
BMF
Texas
People use all kind of crap. I once watched a guy pour half a bottle of ATF down his carb. in a grocery store parking lot. He was driving an old ford pickup and said he doe's this every 3K or so. I coulldn't believe the old thing cranked. Drove away in a cloud of smoke though.
MUDDY
IDAHO
dont do it. atf isnt designed to be burned. they say it more of a solvent instead of a lubricant. the p7100 pumps are more forgiving but they say it will harm the later vp44 and earlier ve and the new cr w/ its pricey injectrs. stanadyne,powersrvice,howes, redline,,,,,,,etc all make goood stuff designed to run in the fuel
PackRat
Buzzard Pilot
Kansas
That was a widely used practice, among gasser, back when I was on the service bay. Lil old ladies who never get out of town, come in complaining of a poor running engine, or top end noise.
Last thing, before qiutting time, we'd pull the air cleaner, and give it a dose of ATF, while holding it about 3/4 throttle. When you get good at it, you could use the ATF, to keep the engine from running away with itself. Let it sit overnight, and go run the carbon out of it, the next morning.
A pretty good trick, is to put a T in your buddies vaccum line, and stash a bottle under his hood. One it starts sucking the ATF in, it will buck, smoke, and generally be embarrasing. :rotflmao
TooMuchBoost
South of Atlanta
I like 2 stroke oil especially if you are running K-1. It raises the BTU's, adds some lubrication and enough of it will raise the HP.
div7racer
Southern Calif
Thank you all for your replies.I guess I should be putting something in the tank every other fill up,and it wont be atf !I will go to Pep Boys or Kragen or the like and see whats available.Thanks again,and Happy Holidays to you all.
PADIESEL
HIBBS,PA
My ???? most atf is red will that die the fuel red? Then what if the dot dip your tank??????
holtzer1
missouri
your screwed cuz they will never believe its atf...all they will see is dollar signs for a huge fine, untaxed fuel :puke: DOT
wanderer
Obtuse Degenerate
Word dude. I was dipped a few years ago, and I was admittedly "dirty" with dyed fuel in one tank. While I was talking to the revenuer, I asked about ATF, and he told me it would show up as the governments' dye, and you would be fined.
PADIESEL
HIBBS,PA
That what I was thinking damn just drop an extra dollar on the right stuff.....
steved
ATF will eventually eat diesel injectors if used a lot...it has FRICTION MODIFIERS in it which act the opposite of a lubricant. It also contains a lot of detergent which, will also clean deposits out, but not all deposits are bad. I don't know how much is harmfull, but someone dumping a quart into 200 gallons versus us dumping a quart into 35 gallons is a significant difference.
I have used ATF to remove carbon from gassers by dribbling it into the carb...it works great, something about the cold ATF hitting the hot carbon causes it to spall the carbon off from components.
I too have been dipped...whenever I run crosscountry, I quit using Marvel Mystery Oil for the same reason...probably not an issue if you have fuel receipts with you, but I don't want the hassle.
steved
tomm
With the onset of ULSD I atarted adding Power Service and since my LP died last week, I am adding 10 oz of TC-W3 2 stroke oil per fillup as well.
ATF is a no no as is anything synthetic.
Folks say 2 stroke will clog injectors but the Power Service keeps em clean.
No more smoke than usual and engine is quieter.
olsen726
