So I got the results of my sonic check today and the thinnest spot is .239”. Since the test is a spot-check of many points there may be spots that are thinner. The cylinders are consistently thinner at the tops, and are well over .300” as you travel toward the bottom.
I would need to bore ~.030” to clean up the cylinders, which will remove a further .015” from the wall thickness. The engine is true a factory turbo with 201k miles and an unknown history (I’m assuming “neglected” based on the condition of the truck I pulled it from and the engine internals).
What is the acceptable minimum wall thickness?
Anyone come across actual recommended specs?
It’s very easy to spend other people’s money and say “just sleeve all 8”, which I may do, but at $800+... I’m already going to have more in this engine than the truck is worth. Additionally a 1/8”(.125”) sleeve doesn’t “add” thickness other than what is recovered getting back to a stock bore (about .015 in this case).
The machinist also mentioned the possibility of a ceramic coating of the coolant passage, something he’s done on the race engines he’s built. Anyone heard of this?
