A word about dieselkleen
nelstomlinson
Delta Junction AK
16oz. per tank, so a quart split between both tanks. Any cheap 2 cycle works great.I try and buy it by the gallon so I am not always running out of it,plus it is cheaper that way. I do this in all my diesel engines, since they are older then 2000.
Rock
Same here: a pint of the Walmart Supertech 2-cycle oil per tank. That works out to a little more than an ounce to the gallon, since the tank usually isn't empty when I fuel up. Also, this time of year I put in a pint of Powerservice white bottle additive per tank.
Isaac Ristow
Somerset Wisconsin
What is atf made of exactly and do you use that versus the 2 stroke oil?
adding lubricity to the fuel is adding lubricity so you could really use any oil. I use atf because it's supposed to have quite a bit of detergents in it to keep stuff clean. I've also had good luck with lucas fuel treatment it's pretty thick too
Cubey
Van dweller
USA
mexicanjoe
texas
reading these comments I cant help but believe that diesel kleen is doing a great job for my engine. that said, when LuLuBelle really runs like a crap I use Butchs extreme. Don't know what's in it, but by hanky it works....So I guess for maintaining the status quo Ill keep using diesel Kleen....Hope to make it to Wespauls place one more time.......That dude is amazing when it comes to idi engines.
Farmer Rock
Glen Rock,PA
According to their site, it also has a lubricant:
"Contains Slickdiesel® Lubricator to protect fuel pumps and injectors from increased wear caused by poor quality Ultra Low Sulfur Diesel (ULSD) fuel"
https://powerservice.com/psp_product/diesel-fuel-supplement-cetane-boost/
I realize that it is supposed to be a lubricant, but my point was that it doesn't seem to smooth the engine out any, or make a noticeable difference.
I am kind of old school with my techniques. Here's the Ole' list
For a deep clean of the entire fuel system-
*40% kerosene to 60% diesel.:Thumbs Up
For IP lubrication-
*16oz. Of 2 cycle oil per tank.:Thumbs Up
A little extra something in the engine oil-
*marvel mystery oil.just dump in the whole bottle!:Thumbs Up
Anti-gel-
*power service or peak.:Thumbs Up
I just bought 10 quarts of peak at ollies,for 1.99 each, so I am currently using peak.
:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up:Thumbs Up
Rock
themechanicalford
TheMountains
For IP lubrication-
Anti-gel-
Rock
Ive used marvel for years and years and now that I'm thinking about it, I wonder about using it in the fuel in place of say the 2 stroke oil? Any thoughts?
Farmer Rock
Glen Rock,PA
I don't see why not. I believe marvel is recommended for use in fuel systems, so there is no reason not to. I think that it all comes down to price. You can use old motor oil if you want and trust me, there are lots of old farmers that do that, but they all do the same thing. I like 2 cycle because it is cheap, burns cleaner, and I can buy it in bulk.
Rock
MtnHaul
California
https://www.dieselplace.com/threads/lubricity-additive-study-results.177728/
DieselKleen ranks fairly low in terms of lubricity but may offer other benefits.
Personally I like the optilube products but for off-the-shelf I go with Stanadyne or Hotshot's sumpn' or other. Sometimes I run some ATF but it seems to cause a slight drop in power, at least at the rate of 1 quart/tank.
Farmer Rock
Glen Rock,PA
I personally don't run atf, because it's a lot different then the old atf that was great for diesel engines. The new stuff has so many additives and detergents that I don't like the idea of running that in my trucks or tractors.
Rock
MtnHaul
California
Just curious here, but what are the differences? Detergents, dino vs synth? Would Type-F ATF be closer to the older stuff?
ttman4
Last Nite's Dream..
If I can lite it with a cigarette liter & it burns I'll stuff it in & run it..... WMO, ATF, 2cyl, grass, hay, tree limbs, weeds, trash. hahaha LOL
Ah seriously, I run lots of stuff in my WMO mix rear tank, Diesel & ATF or 2 cyl mix in front tank.
ntjapkes
