Where does the tachometer in the dash get it's signal from? Occasionally I am getting the "lazy tach", where at an idle up to 1000 rpm or so the needle is at zero, but as soon as I speed the engine up, the tach jumps up to what I think is an accurate reading. The reverse is also true, when coasting to a stop the tach indicates correctly all the way down to 1000 or 1100 and then just falls down.
The kicker is that occasionally, the thing acts perfectly. Usually, after a long interstate cruise it works fine.
This is not a problem in and of itself. However this behavior affects the transmission in some pretty annoying ways. First, if you are going about 35, the trans will shift up-down-up-down, presumably because it sees a low rpm and shifts down to raise engine speed, which is too high in the lower gear, so it upshifts again and so on. Second, if you are easing around (like through a parking lot) under 1000 rpm, (the tach shows zero) and the computer decides to shift to second, the trans will throw a code, o/d light blinks, and you are in limp mode (presumably because the computer doesn't see a rpm reading) until you can take the battery off for a few minutes. That is really annoying.
I have cleaned and greased (dielectric) the connectors on the firewall and at the transmission, as well as the two-pin at the tach sensor. So the question is what is my problem? Do I need a new tach sensor?
