Yeah, buy some a/c line flush, unhook all ur lines, receiver dryer, and evaporator. flush em out good with the solvent and an air blower on a compressor. Install ALL new orings on your lines. Carquest bout 20$ for the whole big kit of orings. The solvent will not hurt the a/c system if u dont get it all out. It will dissipate. If you have the 134 adapters u can skip the next step. Personally i prefer a dual gauge system to monitor the high side instead of just charging. You will need to add 7oz of pag 46 oil to the compressor/lines wherever u wanna put it. MAKE SURE YOU FLUSH THE COMPRESSOR. Dont forget that big piece, alot of the old grime and gunk likes to sit in there. I will advise you to replace your orifice tube. It just helps get it a little colder and they tend to clog on ocassion. Charge the system with 2lb 3 oz of freon. round bout 2 1/4-2 1/2 cans. I would recommend placing a big fan infront of your truck while charging, It just helps with the high pressure on the condenser.
Overall
Solvent/Flush $12
Orifice Tube $2
Pag oil $7
Freon (its up to you. I would prefer the R134 with stop leak)
O ring Kit $20. Unless u wanna match all the orings up individually. Its up to u.
So round $60 you will be good as new. Cheaper than buying R12 at like 60$ a lb
