f250guy
New to forum...trying to determine problems with my 97 f250. bought the truck about 7 months ago, it is extended cab, full size bed and is stock in setup. it is an occassional drive and i noticed that going uphill coming from a stop it losses power and rpm's. it progressively got worse, when started it only was after warmed up. i replaced the uvch, the valve gaskets, and the icp. it now occurs almost immediately, i have not been able to get truck more that a couple miles from home. pulled the oil from hpop and filled with new last night, no difference. the oil is at correct level and was changed a couple weeks ago, new fuel filter, new screen going into fuel regulator. have buddy with with scanner/logger but he is not sure what to log or look for. any ideas?
