93turbo_animal
ok I got a friends 96 that won't start when I checked the codes it had 2 codes for cps and 1 ICp preasure low or out of range. The truck cranks fast the tach moves and the wait to start light works and the fuel pump is pumping. The truck does not smoke when cranking we replaced the cps since it had 2 codes even though the tach was moving still no start. they replaced the gp relay even though I told them that wasn't it and the truck started and ran a couple times then it wouldn't start again and hasn't started since. So they checked the wires and found wires bare that go to the IPR so we fixed those but still no go the HPOP is full of oil and still does not smoke when cranking so what would be the key sensors and connectors that would not let the truck run at all to check?
