Thefarmboy21
My buddy just aquired a 96 PSD and its running rough to say the least... It idles roughy, it revs slow and obviously doesn't have any power. BUT we have isolated a couple of the problems. The first was that the exhaust was about 75% stopped up from mud daubers nests. After we got that cleared out it sounds better and was more obvious what the problem may be. Next we started unplugging/replugging the 4 valve cover plugs until we unplugged the one that made no change....from drivers side: ran exactly the same whether it was plugged in or not. The plug doesn't look burnt, SO what might be the problem? Bad gasket? Bad relay somewhere? He did say that it blew a main fuse, so I assume that somwhere between those two injectors and that fuse, that something is burnt up or touching. Opinions....do we start by tracing the harness toward the fuse, or from the valve cover to the injectors??? Thanks!
