96 Powerstroke
rcarp25
Terre Haute, IN
I have a 96 F-350 swb could I do a zf6 swap from an E4OD? And if anyone has done this how hard is it to do?
Correct. There were slight changes from the obs to SD trucks, but it will work.
Also have to add the trans fluid cooler and lines.
rcarp25
Terre Haute, IN
Ok thanks for the info. It will be a while before I get to that part of the build just want to know if it was doable
dunk
Dunce
NJ
I recall reading the ZF6 is taller and needs the floor pan sliced and peeled back and a bit. Otherwise should bolt up I think.
m2rtin
